Spotted Cejays 32 in the city. Looks like the flock of Albatross like to sit above it. Dude needs a wash to get that mess off......
Yeah I noticed that when I got back :P least they shit on the windscreen and not on the paint.
https://www.sau.com.au/forums/topic/30059-spotted/page/603/#findComment-5036978
so you're coming out tonight Kat? DO EEEET DONT BE SOFT!!! you always said you'd come out when it warmed up, and tonight should be rather nice! :)
Well you missed out cause you weren't there when I went past. So I went to the Museum followed by Brodburger. Maybe next time! :O
https://www.sau.com.au/forums/topic/30059-spotted/page/603/#findComment-5037392
Had to get the beast jumpstarted tonight cause of a flat battery. Apparently it was the dude's second Skyline in a row tonight, black one also having issues. Anyone from here?
yes its a bit very late and delayed but it was proberly me i think... assuming ur talking about nrma haha...its a black 32 u prob drove past it last nigth at the museum was parked in between a white s14 and maron/silver vl calias
https://www.sau.com.au/forums/topic/30059-spotted/page/603/#findComment-5037642
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
