Also spotted myself this morning dropping the 33 off at inline...can't wait to get her back on friday, gonna be a whole different car! especially considering the total damage to my wallet comes in at roughly $3700, it'd wanna be good! Who wants to go for a drive this saturday? lol
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5179586
it will be well worth it! mine gets finished on friday finally! what are you getting done to it?
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5180407
Spotted black 33 on drakeford drive this arvo at the erindale dr intersection. Gave a wave, got one back :D
haha that was me :D . I saw a burgundy(well lets say maroon) r33 outside of lanyon maccas around 1:00am this morning. May have been leaking something as it left a trail after it parked for a few . could have just been there already though not to sure.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181378
Can you let me know what you think of their work v costs/value for money. as i am considering Getting them to sort out some bits and bobs for my pulsar.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181937
I'd say many people here (ZCR, Turismo, GTRKat+many others) could vouch (and likely will) for Chris and the team's work at Inline - it's the main reason I've taken my car there. Of course I will post up results+thoughts once I'm done.
Only negative thing's I've heard about them is that you obviously pay proportionately for the work you're getting - meaning they're reputed as expensive but well worth it, and that Chris has a tendancy to go a little over the top, and have parts replaced that don't 100% need to be. That being said, if you're going to spend some money, and want good results, I've heard it's the right place.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181989
Thats cool
Plan is to replace Shitty and way too stiff D2's for TEIN in the Pulsar. Every other bush, link, brace, nut and bolt that can be changed has been done by a well known and trusted suspension shop in sydney. Appears the last owner ran out of coin when it came to the coilovers.
Well i will look forward to your feedback (and getting his quote).
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5182221
spotted a very menacing black R33 in Weedon Close at ~430 this arvo.. it was very black, super dark tint, nice body kit and gold GT-C rims.. looked fkn mint.. for a 33 :ninja:
also spotted a silver Stagea right after that next to Rubies turning into Weedon Close
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5182362
Spotted white 33 this morning parked across from Hyperdome on Anketell....License plate reads YFZ-33E
Why did I take note you ask? Well mine reads YFZ-33H
Coincidence? I think not! Conspiracy I say!!! Government is pulling some funny shit here on me.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5185706
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
