rofl pat....that's what you get for going to NZ! :)
Sam, it would seem the dude there operates "In Tune" out of his garage. Seems to get a fair bit of business too, might be handy for small jobs like exhaust fittings etc
https://www.sau.com.au/forums/topic/30059-spotted/page/633/#findComment-5395030
idk, lol. He seemed to have set it up properly. Who knows :S
EITHER WAY, spotted a box containing a hypergear ATR43G2 highflow turbo, now parked under my desk at work. WOOO
The guy in richo who runs intune does top work. Really good tuning and works mainly on rotors I believe. Mainy electrical swell I think. Been down there to have a look and everything seemed good and the guy new his stuff
https://www.sau.com.au/forums/topic/30059-spotted/page/633/#findComment-5407861
