Black 33 on Monaro Highway about 8.00 this morning around Michelago flashed headlights, apologies I was too distracted to wave in time, dark R32 GTR? in my mirrors on Parkes way around 11.45 am, I was in the Blue R32 GTR with the trade plate on the back, silver R32 on William Hovell drive around 10.00ish heading into City.
There were Skylines everywhere today.
https://www.sau.com.au/forums/topic/30059-spotted/page/654/#findComment-5632740
Also saw a yellow 34 driven by a bloke this morn about 7.30 all the way down the parkway.
Not as good looking as yours Shell. Had a stock front/rear bar. Driven like Nanna does...
Yeh i loves my kit!!! so much sexier
Spotted a yellow R-34 GT-T in Erindale today. Wasn't Shell unless she's had an op recently :P
soooo... there's something I need to tell you :unsure:
haha nah I was in Sydney anyway
https://www.sau.com.au/forums/topic/30059-spotted/page/654/#findComment-5638530
Cruised down southern cross drive with a maroon R33.
Also I always seen a white R34 crusing around Holt, up near where the Molonglo river is
I think i spotted you at the lights of SXD and Kingsford. westbound i was turning right and you were going straight? Around maybe 3ish?
I was a in the missus car...
I think i know the white 34 you're talking about. I've folllowed it all the way along william hovell and up into holt.
https://www.sau.com.au/forums/topic/30059-spotted/page/654/#findComment-5638793
Went for my night run last night and was running along the Barton Highway towards the city and seen a very tidy yellow R34 GTT with a blonde lady inside. Nice car!
That would have been me on my way back from Sydney! Yay spotted!! :D
https://www.sau.com.au/forums/topic/30059-spotted/page/654/#findComment-5639403
White R34 with a nismo wing turning off gungahlin drive onto sandford street (mitchell). Was three cars behind in a black 32 gts-t.
White 33 out the front of sign world in mitchell.
Also spotted a pink (i think? might have been purple?) r33 with a black bonnet cruising along william slim.
Edited by k_d
https://www.sau.com.au/forums/topic/30059-spotted/page/654/#findComment-5639797
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
