yellow r34 with wide body kit and no wing in gunghalins and yellow r34 on parkway ( i was in black r34)
Hey,
i saw you as we were both driving on the GDE bridge over belconnen way, i waved but i think you were already passed me by the time i woke up and noticed.
i keep seeing that wide body r34 most mornings actually. anyone know anything about it, i think its a P plater car.
https://www.sau.com.au/forums/topic/30059-spotted/page/663/#findComment-5793454
Spotted the yellow R34 again, was in the bright blue Audi this time.
Made it onto the Gungahlin drive at the perfect time this morning, just as it was opening.
Hahaha and i was driving along the parkway and gunghalin drive looking for an NX.
https://www.sau.com.au/forums/topic/30059-spotted/page/663/#findComment-5793457
Haha well hubby has 1 and I have 2 :)
The NX is pretty dodgy, nice to have as a daily shitter that I can park anywhere and don't care about. Also means when the GTR is offroad (like now) even though I'm hanging out for it to come home it's not an inconvenience getting to work and whatnot.
https://www.sau.com.au/forums/topic/30059-spotted/page/663/#findComment-5793916
yeah that makes sense.
i'll need to get a daily runner eventually so i'm not racking up the K's on the Skyrine
https://www.sau.com.au/forums/topic/30059-spotted/page/663/#findComment-5794035
Couldn't miss a black r33 series 2 flying through our worksite at around 10 this morning in clift cr richards
Came round the bend near 100kph, had to slow him down with our flag man, but still he couldn't slow down fast enough. He passed us travelling around 40-50
He was mouthing sorry as he passed, but damn man. It's a 40 zone for a reason. Working on the road is hazardous enough without cars speeding excessively within a metre of us.
https://www.sau.com.au/forums/topic/30059-spotted/page/663/#findComment-5794397
^^ i know a fella that lives 3 streets away from there with a black r33 with chrome hp designs :/
yea sounds like it could b the same dude, he was wearin chromes too.
We're building road islands all down that street for that exact reason.
I mean, i'm not the one to harp on bout speeding, but there's a time and place. We have 40 signs up and down the whole street, it'd just b nice to not have to worry bout getting cleaned up while working for "the man"
How ironic would it b to get wiped out building an island to stop ppl getting wiped out.
https://www.sau.com.au/forums/topic/30059-spotted/page/663/#findComment-5794503
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
