spotted a maroon r32 with FMIC in belco at lunch timish.
spotted a silver R33 with wrx bonnet scoop, huge front bar with mesh grill and mesh infront of the FMIC, 20" zenetti masqerades, standard rear bar? with huge angled upward "imfullawater" cannon on the back. not my taste but didnt sound to bad
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5834686
I saw that last weekend in Tuggers.....definitely got a chuckle out of me when I saw it.
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5834793
Think I spotted Jimmy's yellow beast on Gungahlin drive followed by a black R33 just after 5 this afternoon. Was heading in the opposite direction in the little coupe :)
Yeah got out of work a bit later than usual.
i think you're one of the few people that actually notices me getting around.
i still haven't spotted your coupe yet though.
you must be a ninja :ninja:
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5835707
Spotted a 300zx pulling over on drake-brockman dr this morning, then the driver getting out of the car as i drove past.
Engine out.
haha exactly what i was thinking as i scrolled down.
saw a silver R33 with GTR badge but didnt look like a GTR wing on hindmarsh southbound about 5
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5836440
It'll be home within 2 weeks.
This is the second longest time it's ever been off the road in 5 and a half years and I think this is going to be the most worthwhile.
Pffft snapped, he drives a 33 and a hair dressers car :nyaanyaa:
Ahahahaha oh Kat, don't you know a hair dressers car can't have more than two doors! :P
$10 says your car is back in a shop of some sought within 6 months :P
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5836459
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
