Yay I got spotted... But that morning my mind was elsewhere so only noticed what I had to so I got safely to work... *late wave*
Melly if that was you in the pink 33 with white nose you've been spotted twice, I think I spotted you (well that car) in Deakin near the mint yesterday .... if that was you, nice to meet you.
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6187105
yeah she was in Deakin on Thursday
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6187725
Spotted me with a big grin down Lanyon drive this morning boogieng like the devil was after me :D
(pay the fines later)
Nothing but Props for ESP, in particular Glen. Never ever thought I'd say something positive about canberra tuners.
Big effort and an awesome result - Safe @ lightening speed results. Talk about going the extra mile.
Props to CRD for the build - SOLID !
Props to ESP for their efforts and results in the tune. Paid a small fortune but beleive me it's worth a big fortune and more.
/end rant
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6188164
/end rant
Thats awesome to hear Richard. Hopefully i won't be too far behind you with my GTR haha
Will have the boys at ESP to thank for my build and tune
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6188203
spotted me getting wisdom teeth out. getting sedated is the best feeling ever, its like alcohol but really intense and you know whats going on, think I might still have a bit in me.
oooooow
Had mine out just over a year ago, being sedated was so relaxing! But yeah the bill hurt. Enjoy the next week or two eating ice cream!
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6190626
Thank god I have parent. I barely even remember writing that :wacko:
HAHAHAHA Zane and Mitch loved me on when I got mine out... NOT...
Some of the Sydney crew saw me too, at Superlap I was sitting on a concrete barrier and kept dropping in and out of consciousness because I was on endone so Zane and Mitch kept sticking their arms out to stop me falling off backwards... I think Shell was even there...
I don't remember much of the time...
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6190634
Yes, yes I was :D
I was lying on the grass trying not to throw up from epic hangover, and you were sitting next to me yabbering away deliriously. I remember you being super paranoid about your drugs like someone was going to shiv you for them.
There were cars or something too...
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6191195
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
