Well, you need to book the skidpan. The whole thing. It's in excess of $1000 if I recall, and that's only for half a day. You really need to organise a group of at 10 cars in order to make it financially viable.
https://www.sau.com.au/forums/topic/30059-spotted/page/718/#findComment-6232416
saw the f**kers in the car park. They were booking everything they could. Was concerned they were looking for nice cars so parked elsewhere. Even though the 34 is stock it has nice rims which attracts like blow fly these pricks
Dont need to go over the pits AGAIN!
https://www.sau.com.au/forums/topic/30059-spotted/page/718/#findComment-6240725
