That 32 GT-R out the front of woden is ALWAYS there. like every day : | do we know who owns it?
Spotted a white 32 GTR parked out the front of Woden Cinemas.
Also on my way home about 9:15 I followed a silver 33 GTR which turned off into O'Malley
https://www.sau.com.au/forums/topic/30059-spotted/page/724/#findComment-6264690
spotted black series 1 r33 flying though narrabundah on what must have been 22inch or more bob jane chromes
f**k I wish I could sell them and buy something not so bad
They are 19" and trust me I don't want them
Anyone keen to buy them haha
Spent all my money on the engine parts
https://www.sau.com.au/forums/topic/30059-spotted/page/724/#findComment-6268507
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
