Yep, that's the one :P looks like shit huh? hahaha
Also for the record, I own that van....hahaha yes, I'm THAT lame. I bought a bright orange van.
I live just up the road and use your street as shortcut to avoid that top round about.
The organge isn't so bad I guess....Paint some black GT stripes on it and your good for 10% more power! LOL
Your R33 looked good to me mate.
https://www.sau.com.au/forums/topic/30059-spotted/page/738/#findComment-6344022
The R33 needs a fair bit of TLC on the outside unfortunately, front bumper needs slight repairs and overall needs a complete respray :( otherwise mechanically she's pretty sweet and in good working order (albeit unregistered lul)
Yeah the orange isn't completely horrible, little better than the plain old white/grey colours vans usually are. I gotta get me an SAU sticker off Shell for the rear window though! Black vinyl GT stripes would be pretty sick hahahaha, I'd totally do it.
https://www.sau.com.au/forums/topic/30059-spotted/page/738/#findComment-6344035
Spotted a Silver R32, a Red and Black R32 drift pig with brush painted R34 widebody kit and a 200sx all at Bob Jane Belco this morn whilst spotting my New Tyres going on at a F@#kin' cheap price due to the managers F@#k up. :banana::bunny::D:woot:
Edited by Not a Pulsar
https://www.sau.com.au/forums/topic/30059-spotted/page/738/#findComment-6345001
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
