I reckon! We've got our turf nicely figured out... yours in the AM, mine in the PM. Don't need no hoon newbie!
Spotted a black R34 this arvo.... I can't remember where, Athlon Drive maybe? I think we both spotted each other too late to wave lol
https://www.sau.com.au/forums/topic/30059-spotted/page/755/#findComment-6502409
Yep that was me. Pretty sure it was going past Narrabundah High School Friday arvo. We went past each other so quick a wave was too late haha
https://www.sau.com.au/forums/topic/30059-spotted/page/755/#findComment-6505831
