the r34 gtr vspec is treated like a hack commo from qbyn or kambah
resides in the same complex
i'm impressed to hear it's been washed
My god if i had a bayside blue GTR it would be washed every day! so sad...
Edited by Anfanee
https://www.sau.com.au/forums/topic/30059-spotted/page/772/#findComment-6611320
4:11pm today, Spotted a yellow R34 turning onto the GDE, leaving Mitchell. I was about 15 cars back.
I'm guessing it was Jimmy_8472 ???
My workmate also spotted Jimmy at 7.30am the other day..... he thought it was me for about 2 secs and then realised the time of day :D
Hi Guys :D
That would have been me both times.
It seems I'm popular yesterday...
https://www.sau.com.au/forums/topic/30059-spotted/page/772/#findComment-6616774
