Spotted Kat in the GTR around 12.30! on teh end of the Monaro!
Yay spotted!!! What were you in??
I spotted a white R34 on the way home going past the airport. I forgot to wave cause I got so excited I was in the GTR and someone else waved at me!! LOL :)
https://www.sau.com.au/forums/topic/30059-spotted/page/776/#findComment-6632212
i was in the stagea but was kinda behind a bush driving the other way!
https://www.sau.com.au/forums/topic/30059-spotted/page/776/#findComment-6632649
Yep pretty sure that was me Kat ... And yes for once I did get a chance to wave ... Nice to meet you.
Btw ... The GTR looked very nice
Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/776/#findComment-6632828
