Yeah i used to be his dealer... He could get his weekly fix. Of games and such from EB. The amount of free crap i gave that guy haha. Including the MW3 boombox speaker. Rigged that slightly!
https://www.sau.com.au/forums/topic/30059-spotted/page/788/#findComment-6673812
i used that every day! pity you couldnt get me the fridge either!
https://www.sau.com.au/forums/topic/30059-spotted/page/788/#findComment-6673865
Spotted that orange 33 again with the female driver... no wave
I think I know her.
Red P Plate on the back
She came into the shop just before.
She isnt sure what people are waving at but told her to wave back at the skylines that go past waving lol
https://www.sau.com.au/forums/topic/30059-spotted/page/788/#findComment-6673917
Ahhh I see, nerd friends..
https://www.sau.com.au/forums/topic/30059-spotted/page/788/#findComment-6674084
-7's went in. got a power fc ready for it after chrissy and ill be putting 1000cc injectors in it and then its DONE. Until something breaks...
LOL there's no such thing as DONE no matter how hard you try to tell yourself.
https://www.sau.com.au/forums/topic/30059-spotted/page/788/#findComment-6674248
Pretty sure we all had that discussion yesterday at ultimate tunes lol.
I was the muppet in the lennock shirt.
ahhh that was you! Yeah i have the cash for injectors now... SO tune ECU injectors in early jan...
https://www.sau.com.au/forums/topic/30059-spotted/page/788/#findComment-6674434
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
