Speaking of spotted, does anyone know who owns the silver stag at the conder servo? i assume he works there. ive seen it a few times now
yeah i've seen it there a few times. He was also working near my work at one stage.
I spoke to him once when i got fuel when your car broke remember?
https://www.sau.com.au/forums/topic/30059-spotted/page/804/#findComment-6731374
White S2 R33, Gold rims with silver lip at Jammo Trash n Treasure, FMIC had some kinda Red writing.
Had ACT plates but also a plate on the dash "MY TOY" @ 10am.
(Rims similar to Richards R34)
https://www.sau.com.au/forums/topic/30059-spotted/page/804/#findComment-6734218
I know him. His name is Enrico and works for supercheap in gunners
https://www.sau.com.au/forums/topic/30059-spotted/page/804/#findComment-6735149
Spotted a silver R34 yesterday but I can't remember where or what time haha
Actually it was probably around 5pm cos that's when I went to a friends house.
Coulda been me, Was heading back from Shorty's place in Kambah ??
https://www.sau.com.au/forums/topic/30059-spotted/page/804/#findComment-6735430
Hmmm I'm pretty sure they weren't your rims... but I didn't get a good look. Actually, I'm positive it wasn't you driving now I think about it lol
Spotted Shell turning right onto Hindmarsh from Yamba Drive around 2:30
Missed this! I think I remember hearing a Skyline but couldn't see one!
Spotted a white R31 that sounded pretty good turning onto Beasley Street from Athlon Drive about 2.30pm today
https://www.sau.com.au/forums/topic/30059-spotted/page/804/#findComment-6735754
Silver 34 may have been me :)
https://www.sau.com.au/forums/topic/30059-spotted/page/804/#findComment-6735863
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
