The black R34 could have been me. Havent lived in Canberra long but yet to see another black 34. Seen heaps of Skylines around, wish I knew about this thread earlier on.
(since I haven't seen you post before) WELCOME! haha I've seen a couple of black GT-Ts around, though not very frequently at all. We've got a couple of yellow ones, few white ones, few silver ones...not sure what other colour R34s I might have seen around though.
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791852
I have gone sideways at a round-a-bout. Needless to say, I did 40km/h the rest of the way home. I'll be curious to know if your revs went to redline which then made your turbo swirl you around more or if you clutched the whole time.
(I hope that made sense, because I don't even know what I said :D )
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791854
:laugh: turbo swirl
Usually when people get sideways by accident, it's because it's wet and they haven't learnt trottle control in a powerful rear wheel drive car.
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791953
:laugh: turbo swirl
My interests quote allows me to look silly ! :(
Given it's wet though, your tires would spin a lot faster (No traction) so your revs would be like shooting up a lot quicker given you'd be accelerating to give you spin (kinda). So when I did it in my non turbo Datsun Stanza with rally spec wheels on the back (Hectic) I red lined in half a second due to no friction to grab the tires still. So, I was wondering what it would be like with a turbo giving all that power to the rear wheels and if you'd spin like a crazy man or what.
I seriously need to go into paint to try and make sense of myself haha.
Edit: I made a great paint drawing to describe what I mean, but work won't let me upload it :( Lucky the weekend is coming up. I shall bring my paint skills out again :D
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791965
If you accelerate normally or carefully, your tyres shouldn't spin at all.... that's all I'm saying..... it's when people plant it and don't have a lot of experience. Or perhaps if your tyres are total shit lol.
Hahaha YES we need MS paint here!
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791983
Hope this helps to explain what I am trying to explain.
1.
Approaching the round-a-bout.
2.
Cruising along about to hit boost
3.
Hopefully the review mirror helps explain which way you're facing on the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6792064
My original question was... would that happen above if you slammed your foot down because of the turbo. (I've only spun a non turbo at a round-a-bout and I spun fairly quick.. I'm imagining how quick your RPM would redline because of the turbo).
I'm so confusing myself again!
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6792079
You would bounce off the rev limiter, bounch off the gutter, crap yourself and have a look on your face like this.
I'm guessing Swirl = Spool? :laugh:
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6792084
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
