The black R34 could have been me. Havent lived in Canberra long but yet to see another black 34. Seen heaps of Skylines around, wish I knew about this thread earlier on.
(since I haven't seen you post before) WELCOME! haha I've seen a couple of black GT-Ts around, though not very frequently at all. We've got a couple of yellow ones, few white ones, few silver ones...not sure what other colour R34s I might have seen around though.
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791852
I have gone sideways at a round-a-bout. Needless to say, I did 40km/h the rest of the way home. I'll be curious to know if your revs went to redline which then made your turbo swirl you around more or if you clutched the whole time.
(I hope that made sense, because I don't even know what I said :D )
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791854
:laugh: turbo swirl
Usually when people get sideways by accident, it's because it's wet and they haven't learnt trottle control in a powerful rear wheel drive car.
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791953
:laugh: turbo swirl
My interests quote allows me to look silly ! :(
Given it's wet though, your tires would spin a lot faster (No traction) so your revs would be like shooting up a lot quicker given you'd be accelerating to give you spin (kinda). So when I did it in my non turbo Datsun Stanza with rally spec wheels on the back (Hectic) I red lined in half a second due to no friction to grab the tires still. So, I was wondering what it would be like with a turbo giving all that power to the rear wheels and if you'd spin like a crazy man or what.
I seriously need to go into paint to try and make sense of myself haha.
Edit: I made a great paint drawing to describe what I mean, but work won't let me upload it :( Lucky the weekend is coming up. I shall bring my paint skills out again :D
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791965
If you accelerate normally or carefully, your tyres shouldn't spin at all.... that's all I'm saying..... it's when people plant it and don't have a lot of experience. Or perhaps if your tyres are total shit lol.
Hahaha YES we need MS paint here!
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6791983
Hope this helps to explain what I am trying to explain.
1.
Approaching the round-a-bout.
2.
Cruising along about to hit boost
3.
Hopefully the review mirror helps explain which way you're facing on the road.
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6792064
My original question was... would that happen above if you slammed your foot down because of the turbo. (I've only spun a non turbo at a round-a-bout and I spun fairly quick.. I'm imagining how quick your RPM would redline because of the turbo).
I'm so confusing myself again!
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6792079
You would bounce off the rev limiter, bounch off the gutter, crap yourself and have a look on your face like this.
I'm guessing Swirl = Spool? :laugh:
https://www.sau.com.au/forums/topic/30059-spotted/page/813/#findComment-6792084
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
