Spotted a black stagea with green rims at canberra avenue/hindmarsh drive intersection near fyshwick this morning. Love it!
That's me or the missus, cheers mate.
Also missus "raced" a "skyline" that was blue with big black rims that was so loud it hurt her ears this arvo in the stagea. She was cut cos she got smoked. I said what do you expect it's a standard 1700kg barge hahaha so just bought a split front/dump pipe haha
https://www.sau.com.au/forums/topic/30059-spotted/page/821/#findComment-6804715
Yesterday (thu) at 1330ish .... Leaving the Woden car park near Sth Cross club a very stock looking white S1 33 followed a few minutes later by a white 34 sporting Ps ..
Saw a FB picture of a black R34 sporting L's. :/
No soul would touch my R34 (If I had one).
https://www.sau.com.au/forums/topic/30059-spotted/page/821/#findComment-6805128
i had a 32 on my L's... twas my car lol
R32 GTR?
Different realm of cars, but a bloke I knew had a HSV Clubby R8 (VE - 2006) on his Reds. Took him 2 years to pay it off. Loaded parents :(
My Dad isn't into cars, and I try convincing him into buying something I want nice, but never works :(
On a bit more topic - Does anyone in SAU - ACT own a R35? I've seen one or two driving about (Young Asian drivers). A good m8 of mine knows a R35 owner in Canberra but don't think he is on SAU. Just curious.
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/821/#findComment-6805392
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
