I though %20 or something like that was HTML for space. But now that you mention it, probably is "no blank space" or something.
I believe %20 is for URLs, since you can't have a space between words in a URL.
Either way SAU is a touch broken right now lol, stupid quotes are all demented and there's no emoticons or font options any more
https://www.sau.com.au/forums/topic/30059-spotted/page/830/#findComment-6830833
Spotted RS4-S on Athlon Drive but I think it might have been your other half driving? About 4pm today.
Yep woulda be my gf coming back from her parents. She normally waves to skylines so maybe she didn't see you :)
https://www.sau.com.au/forums/topic/30059-spotted/page/830/#findComment-6832880
Spotted a yellow stagea driving through the city around 11:30ish
Hey Nick, that was me, Was down for 2 days visiting my oldies. Thought I'd haunt my old stomping grounds! Would have definitely been in for a meet up on Friday night, but had to get back the Sydney. Next time.......
https://www.sau.com.au/forums/topic/30059-spotted/page/830/#findComment-6833047
Yeah definatly hadnt seen the car down here before.
Would be worth it next time.
I've gotta get out to that more often as i barely go!
https://www.sau.com.au/forums/topic/30059-spotted/page/830/#findComment-6833993
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
