I think John's cousin or nephew owns Troy's now.
Sounds like it was basically a new car by the time they fixed everything.
Must be nice to have the contacts etc... :/
Same white Stag with black bumper at Mitchell Jax again today too.
What is it with Jax Employees and StageAs? :laugh:
(waits for Taylor to pop up.)
https://www.sau.com.au/forums/topic/30059-spotted/page/863/#findComment-6971939
theres two there and one is been built to make 400watts at wheels old dudes car very nice bloke, other one is a drag car not too sure about it
i think its a drag car i looked inside the interior and it has those 3 gear drag thingys lol
https://www.sau.com.au/forums/topic/30059-spotted/page/863/#findComment-6972971
Lime green wingless R32, followed by a silver R33 GTR on Athllon Drive near Red Rooster a couple of hours ago.
I spotted a lime green wingless 32 the other day on Canberra Ave .. Did he have a 'P' plate blowing in the breeze under the back?
https://www.sau.com.au/forums/topic/30059-spotted/page/863/#findComment-6973666
