A red one? We must be related.
Must admit - you don't see to many red ones on the Tubes or on the streetz
Spotted yesterday:
Black R33 GTST at some rand-a-about at 8am
Today:
black R32 GTST or GTR unsure - civic this morning.
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6991017
If i had an r35 it would be in red. The blood red they paint them in looks amazing in person.
This.
I've seen an aftermarket respray of a much more vivid red too, and it blew me the f**k away. Not even in person either, was just a photo. I don't think I could handle seeing it IRL. Would definitely need to bring a towel.
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6991408
This.
Any pictures of said R35 Princess? :D
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6991457
GET THIS MAN A TOWEL.
This.
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6991541
nah, had it as my desktop background back in '09 when they first came out. Wherever I came across the picture, it was at the time that respraying an R35 was a ridiculous idea for anyone to undertake as they were so new haha
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6991567
Yesterday about 4pm.
Northbound on the tuggers express way a black r33 being booked by Po Po near the Zoo and a about 2km further along another car being booked by Po Po
Both police vehicles were unmarked/undercover. One was a green Ute .
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6992836
I actually thought it was one of the Performance shops in Syd. Maybe Advan or something - dunno...
Might be worth having towed to ESP for $70 and put behind the gates ?
I'd hate to see any R32 GTR stripped.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/867/#findComment-6995965
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
