I think I have said this before bit Driver Education is part of the US school carriculum. Or at least used to be.
I think that is a great idea. Will never happen here though.
I heard some private schools do it - but if you speak with your school perhaps something could happen? I have no idea but when I was at school things like that would be discussed; nothing came of it of course.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077457
3:48pm Silver R32 GTR at the Big roundabout on the Barton.
Did it seem fairly standard, besides big rims? Fairly sure that was a mate of mine Tony. Not a SAU member though
Spotted... Mik, 5hiv, 5hiv's Bro & Rosie in that order.so much RB. :D
Pretty sure I spotted Rosie going in towards charny shops at about 6pm give or take a couple mins. I was at the servo filling up my daily shitter.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077837
If it was a hottie driving that red beast then it was me :D !!
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077861
Haha didn't notice the hotty, just saw a red 34 and thought that must be Rosie, I have noticed from various post your always at Charny lol.
Looked nice mate, next time some more right foot so I can hear it :D
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077926
so much RB. :D
I saw that Maroon R32 going to your place when i was on my way to get fuel as i just got rego today.
My passenger side door got jammed and i just wanted to get home and fix while there was still light otherwise i would have stopped pass and said Hi.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077982
Yay Rego! We will catch up. :thumbsup:
I actually heard / saw you pulling into that carpark. :ninja: then your Bro went past, then you.
Maroon 32 was Mik.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7078010
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
