I think I have said this before bit Driver Education is part of the US school carriculum. Or at least used to be.
I think that is a great idea. Will never happen here though.
I heard some private schools do it - but if you speak with your school perhaps something could happen? I have no idea but when I was at school things like that would be discussed; nothing came of it of course.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077457
3:48pm Silver R32 GTR at the Big roundabout on the Barton.
Did it seem fairly standard, besides big rims? Fairly sure that was a mate of mine Tony. Not a SAU member though
Spotted... Mik, 5hiv, 5hiv's Bro & Rosie in that order.so much RB. :D
Pretty sure I spotted Rosie going in towards charny shops at about 6pm give or take a couple mins. I was at the servo filling up my daily shitter.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077837
If it was a hottie driving that red beast then it was me :D !!
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077861
Haha didn't notice the hotty, just saw a red 34 and thought that must be Rosie, I have noticed from various post your always at Charny lol.
Looked nice mate, next time some more right foot so I can hear it :D
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077926
so much RB. :D
I saw that Maroon R32 going to your place when i was on my way to get fuel as i just got rego today.
My passenger side door got jammed and i just wanted to get home and fix while there was still light otherwise i would have stopped pass and said Hi.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7077982
Yay Rego! We will catch up. :thumbsup:
I actually heard / saw you pulling into that carpark. :ninja: then your Bro went past, then you.
Maroon 32 was Mik.
https://www.sau.com.au/forums/topic/30059-spotted/page/880/#findComment-7078010
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
