i take my hat off to you troy. Having broke your back and getting back on a bike a risking it again. You got some bawlz brah.
Perhaps NOW it's balls, but initially anything remotely risky I did after breaking my back was purely out of ignorance and arrogance ;) was back in the gym 4 days after doing it LOL
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7096061
:unsure:
Yeah that's about right :P did I mention I didn't even get an x-ray done until 18 weeks after the incident? Yeah, I'm awesome.
Bro do you even deadlift.
Very rarely now lol thanks to developing an issue with my SIJ....but I went on to pull 172.5k @73kg
I've switched to sumo stance recently which has alleviated that problem almost entirely, so just gotta get back to doing them consistently I guess
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7096134
If anyone would like a prestige body such as mine - let me know and I'll give you my workout routine and sound tracks.
hahahaha love the soundtrack bit :P
Hence why I bought this the other week - can hit every muscle group without a worry, and obviously no worries at all with the primary lifts.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7096472
Nice i wish i had that. Do clean and jerks too they're just amazing.
https://www.sau.com.au/forums/topic/30059-spotted/page/887/#findComment-7097069
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
