They look good the 86's. Seen a few with kits and some have been done well and some not.
Ideal for the kids around town. Should be interesting when they go turbo - if they go turbo ....
Edit: may end up being the track car of choice in 20yrs
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/893/#findComment-7110182
Yesterday eve - black 32 with lime green wheels near Greenway
Wake up to yourself or you will loose your license (if you still have one) or worse hurt someone other than your self.
- a very silly driver is the nicest way I can put it.
If you know this person say something to him
https://www.sau.com.au/forums/topic/30059-spotted/page/893/#findComment-7112531
I have seen it around too.
https://www.sau.com.au/forums/topic/30059-spotted/page/893/#findComment-7112534
Turquoise s2 R33 GTS-T with tasteful shiny wheels (lolz) around 6:40am on Canberra ave > Hindmarsh dr this morning. Spotted the same car yesterday arvo on the way into QBN too I think, or might've been the same time of the morning. Can't remember lol
https://www.sau.com.au/forums/topic/30059-spotted/page/893/#findComment-7115656
Red 34 heading into Mitchell this Morn.
Also, forgot to mention, White S2 R33 on the GDE a couple of mornings ago. I waved and he was fully Eyeballin' the head turner. :D
I think that was me. Ill wave next time my bad lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/893/#findComment-7117463
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
