Spotted a black 33 S2 Vic plates on London Cct at around 10 this morning and not long after spotted the tail light of a silver 34 in Farrer Place Civic. It was a fleeting glance over a coffee cup but for some reason at the time I thought it was a GTR so it could have been the same one Jeremy spotted. hope so for Jeremy's sake coz that'll make three.
https://www.sau.com.au/forums/topic/30059-spotted/page/895/#findComment-7121504
It was a GTR - saw the badges and all :$ !!! I was walking in the shops with my m8's and I saw this R34 nose sticking out from some trees. I shouted "R34 GTR !!!!" and my m8's asked if I wanted to watch it go past to which I said "yes ! :action-smiley-069: " He did a big U-turn right in the middle of civic shops (Just outside Gus') and drove off. I was so happy(: I swear those GTR's are amazing. Flawless in every aspect of the word.
3x R34 GTR's spotted ! ! ! !
https://www.sau.com.au/forums/topic/30059-spotted/page/895/#findComment-7121534
you sure it was a legit gtr? and not some top bloke with gtr badges.
Also you seem to spot a heat of them :\
Well - I was thinking the same - but he had the GTR front badge as well as the bum badge. It could always be a GTT with a GTR badge. I didn't see if it had flared guards to confirm my findings- However, I'm pretty sure it was a GTR.
I've only seen 4 ! My bad..
There is a BSB one in my street (He visits his brother - who has the R35 GTR) and then I saw Alaan's new R34 GTR Vspec II the other day annnd a silver one at the lights (i think it was the same one I spotted today though).
https://www.sau.com.au/forums/topic/30059-spotted/page/895/#findComment-7121618
Finally spotted the owners of the R32 GTR BSB that I always see around my place. female driver + passenger. So.... I did like all JDM owners do and drifted around their R32 GTR 3-4 times, by this point I pulled up next to them and got their number plate.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/895/#findComment-7123525
hahahha ^^^ sounds like Tokyo drift :D
I saw a black 33 gtr? It had the gtr wing driving past my place just as I was going to get fuel, (western st Yarralumla) at about 11am, then drove to woden plaza and back, and saw him parked in the carpark at yarra shops just now. not sure if he is a member or not?
https://www.sau.com.au/forums/topic/30059-spotted/page/895/#findComment-7123543
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
