Spotted Shiv helping me out on the stock exhaust at his place this arvo. Can't thank this guy enough!
Awesome R33 that he owns as well
Also managed to work out I had the holes for the child restraints. Then after some digging I found them in the glove compartment!!
https://www.sau.com.au/forums/topic/30059-spotted/page/904/#findComment-7140095
:thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/904/#findComment-7140105
Didn't even come around for a cuppa? :(
https://www.sau.com.au/forums/topic/30059-spotted/page/904/#findComment-7140628
Spotted a wanker in a black R33 with no front bumper AT ALL. almost caused 2 accidents, tailgated this poor person and then almost lost it going around a roundabout...
Silver r34 black wheels from memory in the city on northbourne a few days ago
https://www.sau.com.au/forums/topic/30059-spotted/page/904/#findComment-7141032
Yeah was disgraceful.. wheel spin into slamming on the brakes before plowing into a bus.. he just swerved into oncoming lanes without any care in the world.. p plate.. looked like he'd crashed before.. makes us all look bad..
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/904/#findComment-7141066
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
