Around 4ish this afternoon a white 33 pulled up next to me on Anzac Ave, I put my hand up to wave but the guy wasn't looking, although he did eventually give my front wheel a passing glance ... Oh well, I tried, cant do more than that!! :closedeyes:
Then at 5ish .. in Qbn a wingless yellow 33, looked good from a distance .. :yes:
https://www.sau.com.au/forums/topic/30059-spotted/page/911/#findComment-7153874
The good 'ol awkward solo wave. This happens many of times with me. The wave>hair pat always works a treat :P
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/911/#findComment-7154003
Yeah I think we sometimes forget that not all ACT Skyline owners are in here .... oh well, they don't know what they're missing! :bunny:
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/911/#findComment-7154154
Silver 33 gtr black splitter at the river today. The only time I didn't have my skyline. Always happens. Looked awesome and sounded even better !
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/911/#findComment-7155069
Troy's Ex 33 and the Trojan StageA again just before 7:20pm. I Tooted. :D
Lime Green R32 with Black Bonnet on the Barton near Yowani just after 7:20pm. I waved. :)
Silver M35 StageA on Kuringa Drive around 7:25pm. I pointed. :P
I was actually driving the 4door for a change. :woot:
https://www.sau.com.au/forums/topic/30059-spotted/page/911/#findComment-7157164
