She gets out just fine. :woot:
She was driven yesterday and got a Grin and wave from some young P plater punk who then ate my exhaust and saw me disappear into the distance.
Also one of the Hot Chicks at the local Woolies Audibly Moistened when she asked "is that YOUR Skyline?" and I replied "Yeah...she's my baby". :P
and what woollies may this be? :) hopefully she like 2 doors :P
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7157811
but I have this thing, for example, just before I was at kingsleys in Weston and when I was in side a couple of alright looking girls were walking around it looking at it, and being dark they couldn't see my mum in the car.... she winded down the window and said can I help you? f**k she finds new ways everyday to ruin my life haha
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7157814
Taken further...as in, in the Back seat, with easy access due to having 4doors. :rofl:
youseewhatIdidthere? :D
Yes mate, I saw what you did there ... an amusingly clever way, and one of the few opportunities, to justify having 4 doors, however well said and point taken.
My shout after that .. :cheers:
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7158259
Late, I know... (but hard to post with no internet !)
Silver 34 heading south into Cooma 1230 on 28/12 and...
white 34 (looking very lost) on Sharp Street in the centre of Cooma around lunch time, 29/12?
No responses.
Have to introduce you to some checkout chicks at Cooma Woolies Rob....you'll do more than a few laps (trying to get away!!!)
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7159040
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
