Awwwwww .... you took the girl out again!! ...
Yeah, had to collect Ma n Pa from the Hospital as Dad was having more Chemo today...
Despite my age and independence, they don't know about SkyWagon and I don't want to start up the same old, "What do you need that for? Waste of money, Oh you silly boy" etc etc...
Just playin' it cool. :cool:
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7164250
that 33 was near my place a couple of days ago, that sticker is huge :/ I don't see a point to it because from what I saw it wasn't lowered haha
saw a white 33 in southlands just before, big chromies went to park behind it, tho mum didn't want to walk too woollies haha
Might have been me in the white r33
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7164746
LoL ... well that's nice they still take an interest in your life, and importantly acknowledge your car (cars shhh :ph34r:)
And you could not play it cooler than taking them for a drift drive in the 33! :yes:
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7164949
  • black 33 no wing at Stromlo off the cottor road, and that was it.... was going to go for a blast around the cotter... got stuck behine someone doing 55khm... every chance I had to over take he sped up or there was an oncoming car or bike... made a bad day into a really bad day.....
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7165061
breese ( metallic green/blue ford colour ) r33 gtr? parked near the cop station in woden - nsw plates
black 33 gtr with airbrushed lightning strikes down the side going over the blue bridge in Deakin, never seen it before
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7165783
Pretty sure thats the one with the V8 in it. It's for sale.
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7165787
That guy works at the hospital. Its just a gtst aswell, though I think it has a gtr wing
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7165946
Good trick: pull over for 5 minutes.
And wait for a nice long gap in the traffic.
On my coppins runs i wait and keep an eye on the mirror.
Once plenty of time since the last car has passed, you will get a good run.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/916/#findComment-7166703
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
