10 minutes ago on Athlon at the back of the Hyperdome both a few cars apart
- Gun metal 32 GTR with an attractive female driving
- Silver 32 GTR (wingless)
was in my 4door 32
maybe if I was in my GTR they may have glanced over
https://www.sau.com.au/forums/topic/30059-spotted/page/942/#findComment-7313156
Yet you never f**king spot me!!! :D
One day you'll see the crazy woman waving at you.
Hahahaha
I'm sure I will sooner or later, depends what you're driving now days..
I've been away from the forum for a while too, so, there's that excuse ^_^
https://www.sau.com.au/forums/topic/30059-spotted/page/942/#findComment-7322654
Hahahaha
Hehe.
Well if it's me driving it's a bright red E36 beema. If I'm with Pete it's a black X5 but I'll forgive you for that one cause they're everywhere :)
And I'm fairly sure you wouldn't miss the GTR.
https://www.sau.com.au/forums/topic/30059-spotted/page/942/#findComment-7322698
Hehe.
Certainly not gonna miss the GTR, the euro trash however....... :P
https://www.sau.com.au/forums/topic/30059-spotted/page/942/#findComment-7322718
