Spotted Bill back on deck after 2+ weeks dealing with freeeekin Pneumonia, only drove the ol' girl (the car) twice in that time.
Took her for a spin today to catch up with a friend (yes I do have one, but that's about it!) ... and
Spotted a black 34 in a carpark over Weston Creek way along with a 'mint' kinda green 33 in the same carpark.
Very nice to see you all again :action-smiley-069:
https://www.sau.com.au/forums/topic/30059-spotted/page/957/#findComment-7405040
Hi Jeremy .... It wasn't me? I did do a little running around today!!
Well, you would've seen me for sure as when I passed the white R34 GTT it was single lane traffic over a bridge crossing a lake (Gunnerz) around 2pm'ish. No idea where you live so not sure if you live around that area.
https://www.sau.com.au/forums/topic/30059-spotted/page/957/#findComment-7405302
Ah no mate, I didn't get that far north ...
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/957/#findComment-7405357
A bit before 3pm today a black S2 R33 turning off Canberra Ave into Newcastle > Fyshwick. I didn't see a lot of it but looked very straight, I'm guessing paint not original and had led tail/brake lights, I'm not usually into those but this looked ok.
Whoever you are, nice car from the little I saw :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/957/#findComment-7405636
hmmm No idea. I'm pretty sure it was a coupe. Had red P plates if that means anything.
Got Periods
Yep to the P's with a chick driver, if it's a 4 door I seem to see it a lot including having a loo break at Braidwood a couple of weeks ago.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/957/#findComment-7409009
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
