Spotted Mates rates real estate signs EVERYWHERE
End of an era putting that sign on ACT land.... Boooo.
Had a call and meeting with Gubbmint official and $22,000 fine if I continue... Ouch.
Oh well, just going to have to go full Guerrilla marketing in another direction.
Hey, at least I got 12 months out of that!
https://www.sau.com.au/forums/topic/30059-spotted/page/986/#findComment-7541659
Met jimmy last night at the bmx jam.
Such a beautiful gtr!
Thanks Tom, was cool to meet another SAU member :yes:
also that night drove along side a black R34 in weston but wasn't sure if it was anybody on here?
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/986/#findComment-7547923
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
