:wassup:
Why'd you get kicked out man? it was packed as hell anyways.. cruising around was much better, i didnt get kicked out but the scene after 11.30ish was heaps better..
Dayne
I've been kicked out a few times mostly fights but this time my friend got a flask and put some rum in his coke so basically if you knew him you got kicked out
https://www.sau.com.au/forums/topic/30059-spotted/page/158/#findComment-1311019
spotted last night outside cadamy stevie (love the BOV), goog's (my friend creamed, and he likes fords) a silver 33 chirping the tyres and daynes 33 and then today saw andys purple 32 goin down ashly drive then about 2 mins later parked at erindale shops
Yeah I was just trying to make my way home and as I came up on academy there were people everywhere! I didnt know what the fcuk was going on. You shouldve called out or something I wouldve provided more entertainment than you just listening to my BOV... lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/158/#findComment-1311124
:wassup:
Haha, thats unlucky man, was good though:P they needed to kick some people out!!!!
It went off around 1030 inside, everyone was leaving lots of room again:P
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/158/#findComment-1311234
Spotted and had a quick little chat with a Stagea owner in tuggeranong, had R34 GTt rims, was that you Jay?
YAY... I was spotted again. Sorry dude, if I knew that you was you I would've pulled into the servo for a chat. I was running a bit late anyway :P By the way, DAMN those mags look good on your car. perfect choice.
Also spotted a nice gun metal R32 going down Erindale Drive around 4.30. I didn't get a chance to wave cause I saw you at the last second :)
J
https://www.sau.com.au/forums/topic/30059-spotted/page/158/#findComment-1314494
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
