Thanks Santa (the neverending trials of the 400,000klm, 400kw, RB30, manual swapped Stagea)
Unfortunately I can't confirm, because the damn thing died the other week. I can't prove it, but I think the carpark jump started the car backwards - it was fine when I dropped it off (but the auto lights sometimes stay on....), but when I picked it up the car and battery were totally dead :mad:
I beleive it was yellow top D51R. I was happy with it, it spent a lot of it's life flat and kept charging up OK. But of course this was a very custom application.
btw, I should say...she is in for a garret core turbo atm. I killed my 4th china turbo a couple of weeks ago towing a big trailer to wakie.
I'll post up results once available
Looks like an Odyssey in the pic, the sideways mount looks like a good option, looking to get a forward plenum.
I was curious how a smaller battery would hold up.
The chinese just haven't got there yet with turbos hey? Be interesting to see the results.
sorry yes, it was an odyssey, and reasonably large. The model was D51R from memory, but check first! It was a very tight fit between the fuse box and rad support, in fact the edge of the rad support had to be rolled a little. But it was very secure in place, and started every time until some groink killed it for me :mad:
The turbos were fine, I had another car I could drive if this was off the road, and they cost $300ea instead of $2000. So no regrets there. The issue for me is I would kill the china turbo without fail when I did a hard tow, and I think that is because they are only oil cooled and always on boost (small turbo, big motor, big load), they just got too hot and died. Without that I suspect none of them would have failed.
When I went front facing plenum I fitted two 12 volt Applied Power gel batteries. Dunc, I think I sent you a pic. They have been very good so far
My accountant is a mad Zed fan, holds the Oz speed record with one, 129.9 MPH on the salt flats. He put me on to Applied Power. Uses a single in the Zed, also in his 600hp F100 that he is taking this month if the salt pans are dry enough.
Edited by 66yostagea
I have the battery in the boot as well as a surge tank and a metal cover which means I can no longer get 4 wheels in the back with the back seat up. Another reason to go RB26 head on the RB30 as its plenum doesn't intrude on the battery space!
I know what the battery is in the pic. I bought one yesterday from battery world "SSB Automotive" only $115 with 2 years warranty, will see how it goes.
  • 1 month later...
I finally gave in an put a garret water cooled, ball bearing highflow into the china housings after 4 of the china ones died over a couple of years.
It seems to come on boost at about the same revs, but it has less lag (ie time between mashing throttle and full boost arriving)
The guys at Unigroup did a tune for me today, here are the results:
19psi was the max the turbo was happy with, no doubt with a bigger turbo it could make more power....but that is hardly the point is it.
interesting. it feels like the power comes on very early, so I overlaid my last dyno run (china turbo, same boost, same peak power) in blue, and the car when it ws stock in red.
2 points worth noting:
At the same boost, and the same sized turbo, the ball bearing one makes 80% more power at 3500rpm.
The new setup makes more power at 3000rpm than the standard one made at peak power
blah blah blah......
......does it chirp 2nd??
Fat midrange Duncan, gotta be happy.
Duncan your rev limit looks pretty conservative for a forged and balanced engine - looks like it will continue to make power til say 7K?
Here is my tune from yesterday. I was very disappointed with my first tune at 10psi - less than 200awkw. Next at 15psi produced 230awkw and now at 20psi have 280kw so I am confident that I will crack 300 with my final tune at 25 or more psi and another 500 revs (currently limited to 6000) It has always had heaps of torque though just not enough power at the track. Did 1min 24 at Hampton Downs with 230kw so will see if I can do better this Sunday
Hey Andrew, it doesn't chirp second, I put good tyres on it :P It does happily spin all four in the wet at full throttle though. Lucky I am a sensible mature gentleman in a station wagon.
Bob, you are dead right. Conservative is exactly the point of this car and setup, in fact the tuner sounded disappointed that the turbo would not take any more boost. We ran it as high as 24psi (about 280kw) but it just started to ping on repeated runs, suggesting the turbo had probably got past it's efficiency. There's no doubt it is a 350+ setup with a bigger turbo and maybe bigger injectors
You should be happy with that curve, and I'm surprised it is still making power all the way up with the crappy stagea head - or have you got something different cams wise? And it's great to see you hitting the track in it too, it must be classic watching the stagea go past everyone else.
Alex, sorry, no print out with air/fuel, it was a pretty steady 12:1
  • 8 years later...
On 20/02/2010 at 7:25 PM, Duncan said:
...this motor will not make 400kw and do great skids. I just want a great tow car and I am sure I have got it. 250awkw is absolutely heaps of power in the real world and I think this setup will be OK for it.....
well, it did take 11 years and the retirement of the stagea from towing now I've go the Titan....
I dropped the stagea off at Unigroup a while back and asked them to freshen up the engine (400,000klm+ on the original head by now) and to put a bigger turbo and stuff on it. Told them I still didn't need it to make 400kw and they obliged.
Pretty damn whooshy.
  • Like 5
  • 1 year later...
So it got 400kw for it's 400,000klm birthday but its 450,000klm was less exciting. Kel brought it home from a service billowing clouds of steam (happily not on fire....).
The water line to the turbo failed by getting too hot, melting out of the fitting at the turbo end. It was 100 series hose with a fire sleeve but ran close enough the sleeving touched the zorst housing (on disassembly the water return was touching a manifold runner too).
So, I've changed the turbo water lines across to 200 series with the same fire sleeve, and also re-routed it a little further away (not much that can be done with AN fittings at the turbo core). Hope this will last better.
While I was there I decided to address the weep it has had from the zorst cam cover at the rear for years (looks like the original was reused in the rebuild). It now has all new cam cover seals, half moons and a set of those rubbers on the cam cover bolts....no signs of leaks since (other than the bloody rear main which has also leaked since the rebuild....will get to that one day when I can get on a hoist somewhere)
Old seals at top, new below, spot the difference....
Before
After. I love how the turbo beanie even has our race team's name on it, shame they spelled Raceworx wrongimage.jpeg
  • Like 5
While everything was apart I noticed the coilpack loom was in pretty bad condition with a couple of broken connectors, so she got a new one of those as well before she lets me down one rainy night
  • Like 2
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
