Hey all,
I am mounting my new OMP drivers seat and i have to make some mounts. I have to remove the std front mount as i am 6' 4" and the car is caged so i need all the head room i can get.
I am just wanting to know how much room you have between you legs and the bottom of the steering wheel and how far back do you have your seat? At the moment i have been running with 2" - 4" between my legs and the wheel and resting my wrists on the top of the wheel to get a judge for the distance?
Am i on the correct track?
Thanks for reading.
Ryan
https://www.sau.com.au/forums/topic/300856-drivers-seat-position/
yep that sounds about right. I take it you are bolting it straight to the floor (no rails). Also the 32 wheel tilts and slides is 33 the same?
Assuming the wheel slides I set the seat so the pedals are a little close than normal driving (ie easily push clutch and throttle to the floor), then set the wheel a little closer than the normal "wrist with the arms straight" guide. i find sitting a little closer than normal for the road makes it a little easier to drive in anger.
you should consider fitting rails though, you may regret not having the flexability. Or at least a couple of bolt points on the floor.
The 33 wheel only goes up and down, and not in and out (or it's the other way round).
Do many people mount direct to the floor? I've just cut my factory mounts out, and put a bar from the sill to transmission tunnel, but it's a fari bit lower than the factory ones.
In the Silvia I mounted my seat in a similar fashion to Duncan, I'm pretty close to the wheel and using a fully fixed Velo Podium.
The high thorax support means I had to spend another few bucks on a quick release wheel to give some extra space on entry and exit. The Silvia doesn't have telescopic adjustment though.
My wheel sits about 2-3inchs above my knees and I can easily drape my hands over the wheel at the wrists, I'm only 6ft though so I can get away with being a little closer and not worrying about the roof line.
For reference, I also had to centre my mounts properly, I did use the factory seat holes but on a custom frame and the Velo mounts but we moved the seating position closer to the centre of the car when a plumb bob measurement showed the wheel to be off-centre to the seat in factory setup.
As Duncan mentioned, closed gives greater control, especially at the limit, on the condition you're not too close and getting all tangled up.
We played for ages with dummy fitting so it felt right for me. Downside is you have to be the exact same size as me and like my driving position to drive my car. Not such a bad thing in some ways though :down:
Mounting a drivers seat in a R33 is a greater challenge than a R32 because there is no teloscopic function in the steering column. Both cars face the same issue with the four mounting points in the car being on four different planes.
We started with after market seat rails just to get the seat mounted in the car and to start to work out where it should go. The main issue is height becuase GTR seats have you sitting nice and low in the car with good clearance on the roof. The next issue is alignment and the need to move the seat as far as you can towards the middle of the car to provide enough room for the door to close and to clear any bar work that you have.
We are still not totally happy with our setup and I have even gone to the extent of obtaining a damaged shell to fabricate fixed base frames in and try ideas in until we can come up with something that is not a compromise.
Good luck with mounting your seat - it will not be easy.
I actually sit a little too low now, which is hard to believe! I had the rails cut out of the floor and reinforcements added, so now my shoulder only comes up to the top of the door so I ahve heaps of room. It used to be a bit of a squeeze even with the Bride rails, but now I wouldn't want to be any lower.
Hey Ryan,
I run an OMP WRC in my 33 GTR and am 6'3". Due to the roll cage running directly above my head i've had to run the seat as low as possible for helmet clearance . Mines bolted to a 30x30mm square steel tube which i made up to run between the seatbelt side rear mount and the door side and made some mounts for the front out of 5mm flat bar. I have the front of the seat (not the removeable cussion) sitting just forward of the front left mounting (when looking from drivers view) and the pedal reach seems perfect though the wheel is about 20mm too far away (though being taller this might help)
The 33 has a tilt adjustable steering wheel but does not slide forward (well atleast in s1 GTR).
Here's my seat, sorry i didn't get pics of the mounting when the seat is off, spewing i didn't now as it would have helped in the future.
I'll be looking for a dished steering wheel or a longer steering hub once it is off the road for good and won't need ABS for legal reasons (is disconected at track though).
excellent point about the boss....the quick release I have puts the wheel 10cm closer as well, you almost certainly want one so remember to take that into account. and you will love how hard it is to find the indicators after you have fitted one :blink:
Found a photo of the seat side mounts bolted up to the car without the seat today so i edited it to show how i made the mountings.
The ass of the seat sits bellow the square tube at the rear to let the seat get as low as possible. I will be raising it up on my side mountings though as it is a bit overkill in the low department and want a straighter back position.
There are probably easier ways to do this if you have a 33 seat you can steal the mountings from and weld them to the side mounts but this works. I've used 5mm flat bar where needed and hi tensile bolts everywhere to ensure strength.
My biggest issue was clearance when bringing the seat forward...
I'm bolted dead to the floor... The stupid factory hump gets in the way... But it seems nearly perfect for me...
When the cage gets done, I'll move it closer, and lower, and cut the hump out...
The other issue I had was with the shoulder wings smashing the door...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
