Hi Stuart,
I'm using the Nulon 10W/40 for the motor and Nulon for the gearbox. The gearbox one is for Matic J(As well as others). Diff oil should be the same as an R34 GTR me thinks.
You need about 5lt's for the motor and about 8lt's for a fully drained gearbox.
cheers
so Matic J Synthetic for the Auto and transfer, 75w90 GL4 front diff and 80w90 LSD GL5 for th rear diff.....
This sound OK?
Transfer case is same atf as gearbox and steering. Get a 20L drum as gearbox will take about 14L - you need to pump it out via the cooler pipes to get it all.
  • 4 months later...
Any updates on how this went?
Looking to do the same. Thinking of http://www.nulon.com.au/products/Full_Synt...smission_Fluid/ in the auto and Red Line 'Lightweight Shockproof' for the diffs.
Comments?
Comments?
Exactly what I have in my car.
No complaints whatsoever :happy:
Good to hear.
So how much do I need? Is the 20l comment above accurate?
How much of the Red Line?
Thanks
3 bottles of Redline Lightweight Shockproof will leave you with some left over. Get them from for damn good pricing :)
You will need around 8.3L of trans oil if filling from empty.... if flushing, Nissan use 10.5 on their machine.
As an aside, you can also use the Nulon trans fluid for the ATTESSA and power steering (Nissan use Matic D for these)
Edited by iamhe77
Good to hear.
Thanks
On the gearbox without flushing it completely you will be hard pressed getting 5lt's of the old oil out even with twin after market transcoolers( :))....so 5lt's if your just want to change what's in there without flushing. If not I think it's about 7lt's or 8lt's plus a flush....IMO unless your oil is cooked I would not bother with a complete flush.
As for the diff's.....haven't done em yet so.....I guess someone else can answer that.
I had a 60% blocked radiator for a while, so I wouldn't rule out cooked.
Got details on the after market oil cooler? I'm noticing the gearbox seems to start hunting a little bit after getting heated up on a long highway climb. Wouldn't mind getting a bigger cooler in there if it isn't a huge expensive job.
Any trans cooler will be of benefit.
Personally I am running a PWR "6-cylinder" unit and have mounted it on a bracket behind the grill as you can see below (obv without the grill).
There are plenty of cheap trans coolers. Just note that if you are using a 3/8" transmission hose, you will need to make sure of the connection to the radiator cooler as I believe they are slightly smaller than 3/8".
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
