I've got a Black 8/1994 R32 Skyline GTS-T Type M that i'm stripping down. Damage is to the RH quarter, smaller damage to the L&R rear quarters.
Eg of parts available:
LH fog light and corner indicator
reverse lights and number plate lights
some rear lenses
full interior in gc incl trim, dash, wheel, pedals, gbox.
driveshaft
front and rear brakes
mystery suspension, has damper adjust on the front
windscreen, passenger's and rear quarter windows
undamaged left door
diff centre
NO engine, gearbox, ecu
Car is complied and has not been entered into the Written Off Vehicle Register
Just ask if there's other parts you're after and i'll have a look. Can supply pics. Located on the Gold Coast
Neil
[email protected]
0402 546 596
https://www.sau.com.au/forums/topic/30101-wrecking-r32-skyline-qld/
  • Replies 40
inark- i thought it must have been a mistake as well but the date on the compliance plate is 8/94. is there any way of telling off the factory plate?
WazR32GTSt- the left sideskirt is untouched, but the right has a bend in it.
does every skyline owner have broken air vents? unfortunately it seems it is impossible to remove the vents without cracking them so unfortunately the only way i'll be able to sell them is the dash as a whole. maybe you guys should get in contact with someone who can do you a group deal, i think at least 5 people have contacted me wanting them :s
sLo-32- emailing you
anyone else who lives in SE Qld and wants to come have a look for bits is most welcome.
and to the person that contacted me about the mats and centre console cover, please email me, i seem to have lost your message and have photos for you.
cheers
Neil
MM2death- i do have the din slot with door. its one of the items i've had a fair bit of interest in so make an offer.
Ryno- just looked at the surround on the front bar and its got a crack through it at the top. could probably be fixed if you're interested.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
