Ok, Official GT5 Academy Time Trial page, please use the following format to keep it clean (don't necessarily have to use the html formatting but it makes it easier to read), don't bother listing your rank as it will change everytime someone somewhere in the world beats your time.
Minimal chitchat if possible :(
Mode: Tuned/Normal
Controller Type: Normal Control/Steering Wheel
View: In car/Outside/Front Bar
Transmission: AT/MT
Traction Control: 1 - 10/Off
Driving Line: On/Off
Time: 0.00.000
https://www.sau.com.au/forums/topic/301243-gt5-academy-times/
i'll add to this but i don't see much point if we can't discuss it in the thread... I've only played it for a couple of hours and the last time i played was 2 years ago GT4 on PS2....thats my excuse but i'll know there's still room for improvement :D
Mode: Tuned
Controller Type: stock controller (planning to buy a G27 this week)
View: behind and above?
Transmission: best time done with AT (but my times are very close with MT anyway)
Traction Control: 7
Driving Line: On
Time: 1.40.2xx
Update:
Mode: Tuned
View: above
Transmission: AT
Traction Control: 7
Driving Line: On
Time: 1.39.454
Mode: Normal
View: above
Transmission: AT
Traction Control: 7
Driving Line: On
Time: 1.52.2xx
going by the thread replies there's not many people from SAU competing in this??
i'll add to this but i don't see much point if we can't discuss it in the thread... I've only played it for a couple of hours and the last time i played was 2 years ago GT4 on PS2....thats my excuse but i'll know there's still room for improvement :)
Mode: Tuned
Traction Control: 7
Driving Line: On
Time: 1.40.2xx
your right, feel free to discuss
that said, anything lower than traction control 7 and i keep sliding out from the corners, need a wheel and pedals so i can gain some semblence of throttle control
yup i know what you mean. The x button is pretty useless. I'm about to order a G27 so hopefully it will help.....but it might take me a while to get used to it as i've never used a wheel :)
Ahhhhhhhhhhhh I'm shit. I spent an hour or so on this and this was the best i could get. I might hit it up again later in the week.
Mode: Tuned
Controller Type: Steering Wheel
View: In car
Transmission: MT
Traction Control: 7
Driving Line: On
Time: 1.42.203
what sort of times are the rest of the world getting?
If you have downloaded the game/demo whatever you want to call it, you can check up on the rankings in game.
Last i saw, the top time for Tuned was 1.35.xx
I'll take a stab and guess that this is for the F1 car on suzuka?
This is just for GT5 Academy, there is only one track, (indianapolis street something or other) and you have a choice of 2 races, one uses a tuned 370z and the other using a stock 370z
Mode: Tuned
Controller Type: G25
View: Front of Car
Transmission: MT
Traction Control: 4
Driving Line: On
Time: 1.39.5xx
Haven't touched it since the 26/12 but forgot to update, down to low 1:38's. Puts me 300 and something in the rankings.
Will give it another shot when back home around the 6th/7th
Mode: Normal
View: In car
Transmission: MT (gated shifter)
Traction Control: 7
Driving Line: Off
Time: 1:52.757
Haven't tried the tuned car yet, wanted to give it a good go in the normal first.
Edited by bigslick
Mode: Tuned
View: Front Bar (If this is the view where you dont see any part of your car?)
Transmission: MT
Traction Control: 7
Driving Line: On
Time: 1.38.972
Got that time with only 45 mins of playing. Think I'm ranked somewhere in the 700's with that time.
Edited by Dani Boi
I don't think this realy counts as I'm Canadian. However; I thought i would contribute!
Mode: Tuned
Controller Type: G25 Race sim setup
Transmission: MT
Traction Control: 0
Driving Line: On
Time: 1.38.393 Currently 257th
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
