that grey s14 actually sits very well however only the 1 crap photo was posted if u check it out on hellaflush.com it looks quite good but s14s have a crappy rear bar and make it looks like dogs balls. Luke ur fitment is good but geeze sir you could hide a boeing 747 under your car..
not the best pics but all wheels are inline rear runs a fair bit of camber to tuck the top in but 18x10 +20 fits nicely i still have enough traction tyre stretching is not as bad as suggested above within reason. i'd go lower but at 70mm off the ground not much room to move already kinda hard to drive around :banana:
  • Replies 230
My fitment:
It's as flush as I can get with the stock camber/unrolled guards. However, I am still running a decent tyre size (255 front, 285 rear) and even on the track at full lateral load I don't touch.
I'd like the car to sit lower, but in Sydney that's not an option if I want to keep my lower bodywork intact.
i like 350z got any more picks?
http://www.au-z.org/gallery2/v/my350z/?g2_page=2
Look at the pics after 2007-08-01 - my 17" TE37s were a bit of an embarrassment.
For other 350Zs I've taken pics of, check here.
carpark pics are tough with the graffiti etc was that actually in melb?
Yeah, but I've heard they've demolished that carpark now.
Melbourne has the best graf, at least in locations that are easily car accessible.
your car is tough as i say lower it will set it off soo much bit of under scraping is ok :banana:
I have to get mega angle at 1km/hr up my driveway right now to get it into the garage. I have a rule that I should always be able to get my car into my home without damaging the car.
If I move to a location in Sydney that has reasonable driveways and no speed humps, or down to Melbourne, I'll probably drop it half an inch. But, right now, my car is as low as it can go where scraping the front lip/undercarriage is only occasional.
isnt that mexican. just the angle of the shot. Was just toying around with a 20mm spacer. 18x10 -2
heres one with 18x10 +18. 235/40/18
that looks phat!!!!!!!!!!!
love the black and white combination
but it must be hard keeping that baby clean :down:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
