  • Replies 230
sofly - second batch of pics perfect just the 20mm spacer in first pic made it stick out to far but you didnt explain that hence calling it mexican..
aside from that this thread fails.. thread is "wheel fitment, post YOUR wheels" for the most part its random internet pics and cars that are wheels slapped on and need more this, less this to achieve "fitment" maybe should have just made it post your wheels thread..
heres some pics of mine... i consider this conservative as i have only lipped the guards. wheels are 17x8.5 and 17x9.5 panasport g7's and were used a test fit... be prepared for what i have planned when my rig is back on the road in 2011.
and for the haters... this was my daily.. and i never got pulled over.. aslong as the top of the tyre is inside guard its not really a problem. also the rears were almost flat... i can show you pics of my skid tyres and you'll see that just about the entire tyre is worn.
i dont see the point in having a lame (safe) offset... it looks like a commonwhore and is crap. and soo many cars are running around with these kind of offsets and stretched tyres, so i think the unsafe claims of stretched tyres can be put to bed... they just dont hold up anymore.
cheers
Linton
whats the difference in sizes? did you sacrifice some dish for width?
recieved my 17x9.5J +26 / 17x10.5J +/-0 VS-KF's the other day too bad im heading to thailand on sunday got no time to organise tyres and get em on :rofl: im itching to get back already haha, going on an R32, will post pics when on.
recieved my 17x9.5J +26 / 17x10.5J +/-0 VS-KF's the other day too bad im heading to thailand on sunday got no time to organise tyres and get em on :P im itching to get back already haha, going on an R32, will post pics when on.
my last rears were low brake clearance , the new ones are hi :D
fronts are 16mm more rears are 5mm more (and by more i mean less;) )
R34 sedan, 18x9.5 +15 JIC wheels, 235/40's all round, fronts really need a 225, front guards lipped and slight pull, rear's i still need to lip the guards then i can give it more low, just havnt had the time. Work in progress.
if anyone wants them
$8 and there yours :rant:
what? don't sell em to anyone. you'll get tards with sunken battleship fitment sporting them.
i say you only get to have those if a panel of experts deem your wheels to be truly hellaflush.
amen
are you thinking of the same car im thinking of shan? :)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
