  • Replies 418
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
I thought i might post this vid up of APS testing an American G35 in the Victorian Hills with their own single turbo conversion......
Its a fully imported model by the way, left hand drive and all that.....
I dunno if its just me but does it sound like a GTR?
APS Single Turbo G35
(15.5mb by the way)
  • 1 month later...
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
