400R - 400hp :D i think. Just throw 400R GTR in google, i'm sure quite a lot will pop up.
I think it would be very hard, maybe even impossible to find one to buy, i doubt anyone would actually want to sell one. I don't think many were made at all, and most probably something that will be held onto by those lucky enough to have one.
cheers.
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-613798
400R / R33 GT-R (Std.) / 400R improvement:
Overall Length: 4,675mm / 4,675mm
Width: 1,830mm / 1,780mm / *50mm wider fenders
Height: 1,330mm / 1,330mm
Wheelbase: 2,720mm / 2,720mm
Tread: Front: 1,500mm / 1,480mm / *Offset 30mm>20mm
Rear: 1,510mm / 1,490mm
Low Rideheight: 30mm / ------- / *For posture + stability
Weight: 1,550kg / 1,540kg
Engine: RB-X GT2 / RB26DETT / *Increased displacement
BorexStroke: 87.0 x 77.7mm / 86.0 x 73.7mm
Displacement: 2,771cc / 2,568cc
Compression: 8.5 / 8.5
Power: 400ps@6700rpm / 280ps@6800rpm
Torque: 47.8kg/m@4400rpm / 36.0kg/m@4500rpm
Boost: 1.1 bar / 0.6 bar
Power/Weight: 3.88kg/ps / 5.50kg/ps
Headgasket: Nismo Metal 1.2mm / Graphite 1.2mm / *High boost durability
Camshaft: Standard / Standard
Valve Spring: Standard / Standard
Oilcooler: Air cooled type / Fluid cooled Oil cooler
Turbocharger: N1 spec Highflow / T28 standard / *With stronger actuator
Intercooler: Nismo High Efficiency / Standard / *Higher cc/m flow
Cat Conv. : 80mm Low Restriction / Standard
Exhaust: Titanium Dual 60mm / Standard / *400R Lightweight Titan.
ECCS: 400R Special tune / Standard / *High efficiency tuned
Fuel Pump: Standard / Standard
Clutch: Nismo 8.5" Cro-moly / 250mm Single plate
(Twin-plate)
Transmission: FS5R30A Standard / FS5R30A Standard
LSD: A-LSD / A-LSD
Prop Shaft: Nismo Carbon / Standard / *Lightweight
Brakes: Standard (Brembo) / Standard (Brembo)
Brake Pad: Nismo OriginalType 2 /Standard / *For Street and Track
Suspension: Bilstein Shocks / Standard / *Firmer Rate
Spring: Nismo OriginalType D /Standard / *Fr:7kg Rr:8kg
Engine Mount: Nismo Stiff Mount / Standard / *Stronger Mount
Wheels: 10JJx18" / 9JJx17" / *18" 3-piece Forged
Tire: 275/35-18 / 245/45R17
Aero Parts: Nismo Original Kit / Standard / *Improved Downforce
/Cooling
Front Bumper: Nismo 400R Orig. / Standard / *Oil Cooler Duct
Front Grill: Nismo 400R Orig. / Standard
Front Lip: Nismo 400R Orig. / Standard / *Increased Cooling
Side Step: Nismo 400R Orig. / Standard
Rear Bumper: Nismo 400R Orig. / Standard / *Improved Aerodynamics
Rear Spoiler: Nismo 400R Orig. / Standard / *Increased downforce
Bonnet: Nismo GT Type / Standard / *Large Cooling Vent
Over Fender: Nismo 400R Orig. / -------- / *25mm wider each side
Tower Bar: Nismo Titanium / Standard / *Increased rigidity
Badge: 400R Type / Standard / *400R Identification
Meter Panel: 400R 320km/h / Standard / *Nismo Cluster
- 11,000rpm/
Seat: Nismo Embroidered / Standard / *Nismo Logo Standard Seat
Headlights: HID System / Standard / *Optional HID Headlights
_____________________
Nissan released only 99 400Rs in Feburary 1996. The V-spec version of the R33 GT-R was used as a base for the 400R, to produce a road-going version of the LM and GT racecars of the day. Most parts have been upgraded, but it`s probably more interesting to look at what hasn`t been upgraded, namely the Brake calipers/disks, the gearbox and the Camshafts/valves. The standard 5MT gearbox is suited well enough to the increased horsepower, as are the Brembo brakes, which only neccessitated a brake pad upgrade. The primary goal of the RB-X GT2 engine design was the increased torque whih came about with the 2.8L capacity increase. 47.8kg/m@4400rpm neccessitates the Twin-plate heavy duty chro-moly clutch upgrade, aswell as the Carbon driveshaft. All these additions serve not to break away from the base GT-R design, but to enhance the base GT-R V-Spec model one rank up in the GT Street class. The retail price of the Nismo 400R in 1996 was 12,000,000 yen.
(Taken from /Rezz post http://www.skylinesaustralia.com/forums/sh...ead.php?t=29219 )
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-613991
I would gladly give the dude who thinks he can source a 400R 10,000 yen if he can find one for sale... hehehe!
Whats up with these NZ guys thinking that 400Rs are out there...? NOPE.
Fake or not-entirely-legit examples maybe... but the real deal?
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-614110
hey rezz i got something i need clarifying. someone told me that the 400r's engine was not done by nismo, but by reimax. is this true?
i know that u can buy the rb-x engine from reimax via their website (www.reimax.com), but i need to know if the original 400r engine was built by nismo or reimax.
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-614125
They might be sold but does this mean i get 20,000 yen Rezz? :wassup:
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-614162
Mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm........... :D
They're quoting "1999" for the dark blue one... also that dark blue one must be the only dark blue one in existence... I'm not so sure about it. Anybody else think it's dodgy?
The "LM blue" one looks the goods, but I've seen that thing on their website for a long time now (must something like 6 months), but I made that remark above referring to how scarce they are now. You just can't go out and find them at an auction.
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-614235
none of the cars sold by Shin at Prospec are dodgy.He is probably about the best in the business at importing cars.Particularly as he uses Zele International and also his close links with Nissan.Plus he's a great guy too.Most down to earth.
I wouldnt say that he is the cheapest around,in fact far from it,but he only imports the best.Rated amongst the top importers alongside the likes of Newera Imports.Miguel at Newera is also a master at getting the best!
Just my 2p's worth
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-614246
Both cars would definately be the real deal as blitzen has said Shin Inoue is the best will not touch anything less then immaculate and is the man to get very rare GTR's and parts but you do pay for his services ,he used to be the chairman from japans GTR owners club and drives a very nice black R34 v-specII NUR with a heap of mines gear.
What about a Nismo R34 Z-Tune GTR with 600ps from the factory would have to be a more exclusive ride then a 400R wouldn't it?
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-614307
  • 6 months later...
how rare are these cars to purchase? and what price bracket wou;ld you be looking at? and does anyone have some links to specs on them?
Spotted one that sold at aucion in England for the equivalent of $168,000 AUD... Heeeooooge amount of dollars,but it IS super exclusive.Think I'd rather have a R34 V Spec,an R32 AND a trackday special R32 for the same money...
https://www.sau.com.au/forums/topic/30209-400r-skyline/#findComment-903100
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
