if there was no VNs, people would find another car similar to do similar things in. now, you claim speed bumps would help, might reduce it a bit however VNs aint imports, you dont go over a speed bump @ 5kph in a VN. since i still drive a VN (only a week to go before s14), speeds bumps @ 50kph isn't too bad, tried 70kph before, that was a bit of a bump and yeh, suspension wouldn't last doing that either.
The problem is its a fairly wide road and although lots of houses, there is very little traffic. There is ample opportunity to be on the power for quite a while. Although I haven't tried I believe my 33 would be more then capable of reaching 160-180 with a bit of effort on the entry corner (50 zone). At the end it goes uphill for the last 100 metres. Right at the top of the hill instantly hit a T intersection (with this run being the stop and wait direction). (No street signs either)
In this case the VN according to a resident who ran up the road after the car (lol) said the kid was on the power the entire way before braking at the top and trying to get around the corner. So if there were speed bumps and a VN is capable of uncomfortably going over at 80km/h then we would still be better off then we are now. Turns out its not the first time. Our next door neighbour had someone crash into a friends car parked out the front of there house then follow through into their carpark hitting their own car as well a couple of years ago.
I think History has it right. If someones trying to bust their way in. Build a wall. When that doesn't work add a moat. And if your still in trouble then you better invent a gun for when they make it through.
Luke
Edited by l_uk3y
  • Replies 55
well, i didn't think of the differences between roads in the suburbs and your area, mine are mostly narrow and full of cars. i think you ll find a few chicanes more effective along with the odd speed bump (since they are always pain). a hard chicane will slow most people down to below 50kphs, more like 30kph and only a decent car will be able to go past 60kph threw them, plus the speed bumps would probably get rid of a lot of the trouble on your road.
considering you have a wide road with a hill at one end, it's just asking for trouble :banana:
Yeah those ones Peter89, no match for a Landcruiser with a bullbar which has nearly as much steel as a bulldozer blade and a lift kit! Signs have all been smashed over completely and the chicanes themselves are covered in rubber! Non bogans like me are good and can drive through them easily at the speed limit lol
You wont want speed bumps. Seriously. They Make a hell of a racket every time someone drives over it. Kinda like a "thump" as each pair of wheels hit it.
It gets frustratingly annoying. And is surprisingly loud. Not noticed when your driving of cousre, but when one is outside your house and down your street. Its like thunder.
You'd be better off with some tight chicanes or something like that..
But glad to hear that the tree saved your house! And that they were caught.
...adding to that, hoons seem to be attracted to speed bumps, then you'll have the dickheads doing burnouts and donuts in your street or front of your house. chicanes are a good idea IMO, slow people down and don't give these VN driving bogans reason to bag 'em up in the middle of the night.
why don't you invent some speed operated tyre spikes? if a car goes over a certain speed up the street the tyre spikes deploy, as well as a big safety net to stop the car from going out of control into a house.
or like what they have on air craft carriers, have a big hook that catches onto the diff (or rear axle in a fwd car) and slows the car before yanking the arse end of the car off. that'll at least stop them using the street for hooning in the future
Hmmm. My tats ticket wasn't lucky the other night. Sadly $40 won't go far towards something like that and even if it did I wouldn't be able to eat for another week. Damn me and my spending habits.
Just a quick vent. We get so many late night hoons near our place. All they need is a few speed bumps but it will nether happen. Just another tick in the Bendigo Hoon capital of Victoria box to help hurt the people who try to do things properly.
Here's your solution
Edited by .:: GimpS-R34 ::.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
