Pics from SAU Christmas Beachside Cruise/BBQ - 21/12/03
  • Replies 78
Well guys I had a great day. My arm is totally wrecked from throwing vortex missiles!
Some other amuzing moments included the cop that gave the passing group of Skylines the bird :upurs:
Clarky's long ball that accidently broke some blokes glasses.
And the idiot that drove over the piece of concrete! :Oops:
Once again guys the pics are fantastic (shame I couldnt have pushed that blond through my window and driven off with her though! HAHA! :devil2:
Oh - and Im No:9. And Im quite sure No: 13 was that seagull named "Vortex Target" :ak47:
Alan and Andrew, you boys certainly have some mega arms :blast:
That seagull must have shat itself when I threw the vortex at it
Looking forward to the booze cruise if that idea gets off the ground
***NOTE: Max does not normally condone cruelty to animals, it was just there and begging for it and I didn't think I'd be that close to hitting it
16 is my brother... i'm hiding behind 14 (no number for me :D lol)
edit: that would make you 15 (Behind 14) :D
lolz... didn't even see that... i must still be effected by my night cap... :Oops:
OK... this makes it easier.
Was a good fun day - thanks all for coming. We must do these sort of things more often.
I can see a few Vortex's being put on last minute Christmas lists :D
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
