  • Replies 77
Posted Images
no, i more meant, what turbo would you run with an RB24? something rather obviously not standard? Factor in a trip to regency/EPA if you get pulled over(others, not you, I know yours isn;t a streeter anymore). A Stock looking RB26 with engineers cert won't get the same treatment, and if it does, N1's were a factory turbo, use an R34 motor and it would be legal would it not? It would also make the same if not more power than an RB24, and considering it would prob be worth sleeving the block, it won;t be a cheap build.
Cliffnotes:
Officer sees large turbo(high or lowmount) -> EPA
Standard engine bay-> no dramas.
they will be less inclined to look closely at the turbo in an RB20 than a RB26. i can tell u that a RB20 sitting in the engine bay will be a lot easier to put through regency than an RB26, fact.
btw yes i did bump this thread, but there is a small chance i will be getting my hands on this thing again so maybe not a bump for nothing.
https://www.sau.com.au/forums/topic/302957-rb24/page/4/#findComment-5041808
as they say... there's no replacement for displacement
Thats what all the people with RB25s/26s/28s/30s in rwd platforms keep telling me. Makes for a nicer street car no doubt...but put your foot down and all this torque that people pull their dicks over just fries tyres it seems. Fun but no good when you are trying to get out of a corner quick at the track. Thats why personally i have stuck with the RB20, well thats enough of a reason for me anyway. The perceived improvement in torque means gearing, tyre size and quality of alignment, shocks and suspension components all get called into question and the law of diminishing returns hits home HARD because it all costs tend of thousands to maybe go a tad quicker at the track....for the street, meh a Getz is more fun becas eyou can rev its guts out and not lose your licence :banana:
I said it before and will say it again....
1. People who put RB25s in R32s are the sort of guys who sleep with their girlfriend's ok looking friend because she is easy!
2. People who put RB30s into R32s are the sort of people who prefer rohypnol to romance.
https://www.sau.com.au/forums/topic/302957-rb24/page/4/#findComment-5042446
i spent the evening flicking through all the project R32 articles... they start at issue 44 and got through till about issue 70.
with the td06 and the stock rb20 bottom end, they made 239kw, with full boost at 4500 rpm.
with the td06 and RB24, they tuned it for response, keeping the same power, so it made 239kw but came on much earlier with the cams set up for low end.. it also had the ability to rev out to an 8500rpm limit, but the td06 was out of puff by about 6000rpm.
the turbo was changed for a kkr unit with instantly went to 250kw first run... they tuned it and made 256kw, but boost response was now back to the rb20 state.., coming on at 4500 instead of 3500 like the trust turbo, but thats due to the larger turbo.. if it was on an rb20, it wouldnt come on until 5000 or later..
Roy and I are both making 260-280rwkw on 1.2-1.4 bar with TD06 L2's, and I get full boost before 4,500, around 4,200 with a slight manifold leak at the time (that grew bigger).
And I don't run out of puff at limiter 7,600 rpm (but I have a different intake manifold)
I am thinking, unless you want well over 300rwkw (say 350+) don't bother. But by that power level RB25's make sense :banana:
https://www.sau.com.au/forums/topic/302957-rb24/page/4/#findComment-5042459
The perfect road legal RB20 would be rebuilt with just 81mm pistons, run a little more compression, say 8.8 or 9.0:1 and run the std plenum and exhaust manifold. Throw a GT-RS on it with a nice tune, or even better a 2835 Pro with internal gate and it would be a legal looking 250rwkws that would drive nice. A 2530kai could well be the better option for a punchier 225odd rwkws
If you can get the 26 crank and rods cheaply enough then go for it, only the pistons all of a sudden become more expensive as they are customs. I grabbed a set of Tomei RB24 pistons for an absolute steal as it seems nobody wants RB20 gear :banana: This bottom end with an 2835 would be a very nice, legal looking engine.
All those complaing about how the RB20 head flows, it is of course using smaller valves then an RB25 etc and ports are smaller. BUT, look at the SR20 which shares the 2L capacity. The RB20 has a smaller combustion chamber courtesy of its smaller bore, but as a ratio of inlet and exhaust valve to cc of cylinder it still has a better ratio of valve area to cylinder cc. So i would argue that an RB20 would live with a bump in displacement far easier then an SR20 going to SR22 etc.
From my limited personal experience with aftermarket cams in the RB20, they have plenty of cam in them std too. Look at the duration compared to the RB25 and RB26, albeit with less lift. If i try cams then for 2L i wont go over 256/8.5. If i ever need to rebuild my engine using the Tomei pistons and RB26 crank, rods etc i have then i may entertain the idea of going to 260/10.25mm cams because guess what...seems nobody wants the solid lifter gear and springs for an RB20/RB25DE/VG30 so they can be had for a steal as well and have them under my couch as well:)
https://www.sau.com.au/forums/topic/302957-rb24/page/4/#findComment-5042493
Agreed, If I had my time again, I would look around 230rwkw with plenty of response and a standard manifold. The L2 is a fun turbo but not for the average consumer. It is one hell of a ride :banana:
Why I will stick with it? I will never get back what I paid for the kit, which is far far less than what the RRP is.
https://www.sau.com.au/forums/topic/302957-rb24/page/4/#findComment-5042576
That's the cam setup I will be switching to after I have the head CNC'd to add 10cc and +1 valves. Either those or the 270/10.25 pro cams.
Edited by jdmser
https://www.sau.com.au/forums/topic/302957-rb24/page/4/#findComment-5043891
  • 1 month later...
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
