  • Replies 48
I didnt get any :( but i knew i had to bed them in so i did 50 to 0 fairly fast about 10 times then went to 80-0 about 5 times and they were great and i could smell them the noise only started the next day :( but i just thought it might be the rotors as they were new.
it stops very well and i am pretty happy with them when i get the new rear rotors and pads i'll get the brakes bleed with new fluid and give them a hard time see if that makes then a bit quieter :/
When all else fails anti squeal paste is your friend.
Thats one of the biggest failures out there
I'd disagree. Maybe it's the kind that you used? Try using copper grease with shims. This absolutely deleted any noise from mine. I was running DS2500 front and rear at the time and it was so loud I thought it was going to break glass. Fitted the shims with copper grease. Dead quiet.
Running pagid rs14s now, still dead quiet.
pretty sure i mentioned this on p1 and no one noticed....
copper grease on the shims will kill ALOT if not all the noise
what sort of braking conditions are you guys referring to the squeaking with? my r32 has been doing this really bad since i've had it. it has slotted rotors and it squeaks only under very light braking, e.g when im rolling up to a red light and slowly coming to a stop thats where i get this horrible loud squeaking it drives me nuts. on two occasions i've had my rotors machined and it stopped the squeaking for about a week then back to normal. my old garage suggested it could be the pads but i've never gone to the trouble of replacing them when apart from the noise they work fine. the pads do seem to produce a lot of brake dust though. if i clean my rims then maybe after like another 2 days theyr filthy again with brake dust.. does that say anything with regards to the quality of the brake pads?
Edited by jonboy
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
