hey guys girls
my mates F6's turbo started ratteling the other day, so had a look and notice a few loos bolts that seem to help connect the exhaust housing to the centre cartridge where the iol and water feeds are,
we have since replaced 4 of the 6 bolts and turbo seems to be fine
the bottom two bolt i couldnt get too, one is missing completly and the other that is near the oil drain appears to be snapped as i tediously tightened mm at a time (killied me) only to realise after about half an hour it was making no progress,
obviously leaving the turbo in this way is not going to be good, however my mate has started driving it again.. and the rattle has gone and seems to be running fine
also i took the oil and water feeds off to access some of the bolts. im hoping i put them back on properly
i lined the hole up in the bolt with the feed line, seemed to be common sense, is this right??? please say yes
so after all that. should i advise him to stop driving get the turbo off to a specialist to get checked out, or justget the turbo off and try replace the missing bolt and do something with the one that seems to be snapped
i have actually already said if it was my car i wouldnt be driving it, but some ppl cant be told
help would be great, thanks dan
https://www.sau.com.au/forums/topic/303169-f6-gt35-turbo/
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
