Depends.
Around a wet racetrack on a track day I did a few years ago, the WRX's killed everything else - including 2 modded GTR's (both Rexes were MY02 models, one stock).
Current Rex is pretty quick, and probably quicker around a track than an R32, but in a straight line I think the GTR might still beat it. Just coz the REx is ugly don't make it slow.
https://www.sau.com.au/forums/topic/303258-r32-gtr-wrx/#findComment-5030742
stock for stock, straight line, Subaru WRX vs R32 GTR
GTR /
Evidenced here back in 1990 in Australia when the roadtest cars were running low 13's....show me a WRX that has managed that.
Way to many variables at a 'wet' track day to be viable comparo :huh:
https://www.sau.com.au/forums/topic/303258-r32-gtr-wrx/#findComment-5031777
GTR /
love the info , skyline is heavier than the commodore , but heaps quicker
https://www.sau.com.au/forums/topic/303258-r32-gtr-wrx/#findComment-5031807
I heard if you add a 7" muffler back, HKS SSQV, and a giant wing, that WRXs lay down like, 2x the power of any GTR .... :huh:
Is that it? Too much trouble. What I heard was for every stick you have on the rexy, you'll get an extra 5awkw.
School holiday still on?
https://www.sau.com.au/forums/topic/303258-r32-gtr-wrx/#findComment-5031857
Way to many variables at a 'wet' track day to be viable comparo :rolleyes:
Why?
What was the poster actually asking? Straight line? around a circuit? I still think that normal drivers on a normal track (wet or not - the cars were sharing the same conditions)gives a far better representation of overall performance than 1/4 times (unless you are one of these people who can't handle corners and only care about straight line acceleration).
In the dry, the GTR and modded WRX were neck and neck in times, with the stock WRX (and first ever track day for that particular WRX driver) about a second off the pace. Given the GTR had over 450hp at the wheels, I think I can safely say that the stock WRX would have come close to a stock GTR's times, if not beaten them (it was hosing modded R33 GTSt's - wet and dry).
Current model WRX and a stock GTR - no contest. The WRX would kill the GTR around a racetrack - specially if the race consisted of more than 5 laps. But then what would you expect from a 20 year old Datsun?
GTR's are great cars, but c'mon guys - let's be realistic here.
https://www.sau.com.au/forums/topic/303258-r32-gtr-wrx/#findComment-5032345
Itd be good if the list actually had a WRX in it seeing as it was the question.. bet still fun to read.
Yeah true.
Why?
Exactly!
No point comparing the 2.
If you want to compare a R32 GTR with a WRX, it got to be the first generation models = GC8A (11/1992-9/1993) / GC8B (10/1993-8/1994) / GC8C (9/1994)
Compare the new WRX with the new R35 GTR.
https://www.sau.com.au/forums/topic/303258-r32-gtr-wrx/#findComment-5032394
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
