  • Replies 107
lol 300rwkw and a heavy right foot has its drawbacks :D
i get 220km to 3/4 tank, so i'd say 300 to a tank
lol terrible... i have about the same power as you and last tank got 420km.
Before the tune it was doing about 500km per tank, so extra 100kw in the tune and only lost 80km per tank, pretty good.
Averaging 13L/100km over the last 20000kms, track days excluded from calculation.
Babying it day to day though. I can get about 420km per tank before the light comes on. I'm trying my heart out to hit the 500km mark in daily driving without the help of going on long trips via the highway.
Used to get 14-15/100km when I first got the car and it was completely stock except for cat back exhaust. Have to admit that I was in new toy mode though.
Edited by UnCo
yeah mine fails hard cause of stop start driving and the cold start being on for like 50% of the time :D
at my old house it was about the same as yours... and on cruises i get the same as most people with similar power
I get about 400-450 stop start driving.. 500-550 on long trips
cruising around the trip shows around 12L/100KM and cruising on the freeway gets down to about 10 L/100KM
Not to bad for an old RB30E manual :D
Yea... you'd want to get that tune if you're driving a lot. Hahaha. I got 450-500 per tank easy before the tune and after its still 450. But having said that, if I feel like letting it loose a little, it'll drop to 350-400. Still good consumption imo.
Usually between 12.5 to 14.5L/100km
Mods are:
3" turbo back exhuast with high flow CAT
POD
R34 GTT SMIC
Bleed valve set at 10PSI
SAFC-2
Made ~180rwkw when I got it tuned.
Maybe everyone should post up L/100km or km/L instead of full tank. Better way of comparison.
Agreed. Tank is pretty useless because everyone fills up at a different point.
I think going by full tank might be a better representative of the car's overall fuel economy since it will weigh differently when full,1/2 or 1/4 empty.
I am much happier with the consumption I'm getting considering its a GTR though I do miss 500-600km that I got from NA cars.
Nah, not when the term full tank can mean 50 litres or 55 litres!
Best thing to do is fill a tank until full (petrol pump click), reset the trip meter to zero...when the tank is near empty again go fill up at the servo and take note of how many litres it took to fill. Then divide your litres by your km traveled and multiply by 100 for a litres/100km figure.
340awkw i get 200km/tank flat.. no boost..
Shouldnt the car run like a normal car when its not on boost (consumption wise)? That sucks. And thats at 340awkw... I'm curious whats the consumption like for those 1000hp cars... hahaha.
That's what I mean.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
